Old 27-03-2007, 01:40 PM   #1 (permalink)
whoopy_whale's Avatar
Default Registering flash control
I was able to open powerpoint files with flash embedded in it without a problem all these days.
But from today it says that the control is not registered in my system.
How can I manually register it? I don't have administrative rights,so I can't install it from adobe.com
But flash files works in Firefox...
Any suggestions?
In just two days, tomorrow will be yesterday.
whoopy_whale is offline
Old 27-03-2007, 01:43 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Registering flash control
Give following command in RUN dialog box:
regsvr32 %windir%\System32\Macromed\Flash\flash.ocx
If it gives error, then open %windir%\System32\Macromed\Flash\ folder and check the filename (it may be flash8.ocx or something like that) and put it in the above mentioned command.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 27-03-2007, 02:02 PM   #3 (permalink)
I tried it but I got this error...
The file name is flash.ocx itself...
Old 27-03-2007, 03:27 PM   #4 (permalink)
Microsoft MVP
^^ Is there any other file with the name "flash8.ocx" or "flash9b.ocx", etc. If yes then use the same command for that file, otherwise install the latest flash version.
Old 27-03-2007, 04:12 PM   #5 (permalink)
Thanx for the help,Vishal....
There is a file Flash8.ocx in this folder...I tried to run the command and got the same error but with a different return code.
I can't install the latest version 'coz I don't have admin rights.
ActiveX & Flash Betraying ! How to gain Control over them ?? arnold Software Q&A 4 30-11-2005 09:30 PM
how to control flash movie ??? gycapri QnA (read only) 2 05-10-2005 01:54 PM
how to control flash movie ??? gycapri QnA (read only) 1 30-09-2005 03:04 PM
registering an OCX, DLL File veddotcom QnA (read only) 2 17-03-2005 06:03 PM
- by Krow
