is the 915G motherbaord is capable of running DDR rams, iheard that it only runs DDR2?
and i also heard that it uses PCI expresses would it will connect my Pinnacle TV tuner card?
Yes 915G is onl DDR2 compatible. And ur TV tuner card will work fine as it uses a PCI port and not an PCI-E port which is used by the new gen graphics card.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
VOT WAS THAT !!!!! 1 of the main diff btw the 915 n the 925 chipsets is that 915 SUPPORTS both DDR as well as DDR2 in dual chanel , n people say i m a novice
915G:-Flexible memory support, for dual channel DDR2 533/DDR2 400 or DDR400/DDR333 memory, in configurations of up to 4 GB RAM.
Originally Posted by Intel
925X:-Memory support for dual-channel DDR2 533/DDR2 400 memory, providing up to 8.5 GB/s of memory bandwidth, in RAM configurations up to a maximum of 4 GB.
