Old 03-02-2005, 12:31 AM   #1 (permalink)
Salieri Family
hard_rock's Avatar
Location: Somewhere in Internet.......Have dynamic IP address
Default Which is the best book 4 PHP,javascript,Java?
Hey Guyz...........i need a help.
I am interested in webdesigning n I know HTML.Now I want to learn PHP,Javascript.Can nebody suggest a Good book 4 this.
Also a good book 4 Java Programming.(I am a newbie in this.)Thnx in advance.
hard_rock is offline
Old 03-02-2005, 12:45 AM   #2 (permalink)
swatkat's Avatar
PHP-->Learning PHP by OReilly
JavaScript-->JavaScript 2.0:The Complete Reference or JavaScript:The Definitive Guide by OReilly
Java-->Programming in Java by E.Balaguruswamy and Java:The Complete Reference.
if u want quick and easy learning, u can look for Sams TechMedia Publication Books, they have very good books but they suitable for beginners....
swatkat is offline
Old 14-02-2005, 01:54 AM   #3 (permalink)
PHP there are so many open source tuts. Just search in google.
Ish Karo... Ishq karna Tumhara Paidaishi Haq Hai........
Magar Kyon Na Is Bar Watan Ki Mitti Ko Mashuka bana le!!!
:) http://www.aseemn.org
Aseem Nasnodkar is offline
Old 14-02-2005, 01:59 AM   #4 (permalink)
PHP there are so many open source tuts. Just search in google. Dont buy nething.
Old 17-02-2005, 01:05 AM   #5 (permalink)
Salieri Family
hard_rock's Avatar
Thx Guyz 4 ur info.Aseem I have searched lots of tutorials but wanted a book 4 OFFLINE(means when I am not using PC)reading.
A person who wants everything in his life... May end up with nothing at all
-Tommy[Mafia]
Old 18-02-2005, 03:05 PM   #6 (permalink)
enoonmai's Avatar
I would suggest following swatkat's advice. There are no better books for PHP and JavaScript than O'Reilly's Learning.. and In a Nutshell.. books. As for Java, the best I've seen is the Java 2 Programming Bible (IDG) by Walsh, Couch and Steinberg. Covers nuances of the language the others dont. Plus, its very easy for a newbie. Once you're on familiar ground with Java, you can migrate to The Complete Reference and Ultimate Java Programming (Wiley)
Playing FEAR XP/LSW2
enoonmai is offline
- by Krow
