I downloaded a MDF file. I understand that it is a CD image file. But how to burn it? Nero dosen't support it. Magic ISO does but the trial versioon doesnot support more than 700MB my file 740MB
@sivarap
Buy an 800MB disc and set overburn in Alcohol and u can easily do it. Its shareware and u can use it without registering[just some 10sec waiting time].
you can even use poweriso and change it to iso (open image and select saves as iso ) and then burn using nero
little lengthy but if you care to use nero then this might be one of the options..
oh i got it with my dvd writer i still thinks even the trial one will save the image as iso....... cannot be sure..... but still can try if its worth....
U can use Ultra Iso...it can convert an Image file from any format to any other format...that means u can convert a .mdf to .iso or .nrg whichever u like....
