Old 23-03-2007, 08:06 PM   #1 (permalink)
Default Drives Not Opening... Help Required....
Hi friends... there was a virus in my system which has placed a Copy.exe file and a Autorun.inf file in each drive of my system which changed the default double click for drive to Autoplay. I have removed the virus with Nortan and still when i double click on the drive its showing the error that Copy.exe is not available and so i need 2 right click on it and select Open.... Can any one tell me how 2 get Open as my default option....
Thanks In Advance...
RoughGuy is offline
Old 23-03-2007, 08:15 PM   #2 (permalink)
Back to School Mr. Bean !
mod-the-pc's Avatar
Default Re: Drives Not Opening... Help Required....
In windows explorer
1. Go to "Tools-->Folder Options"
2. Select the "File Types" tab
3. Select the file type of "Folder".
4. Click on "Advanced"
5. Under the "Actions" select "Open"
6. Click on "Set Default"
7. Click OK
Desktop: P4 2.8E, Intel 865GBF, 512MB Hynix PC3200, Samsung SV1204H 120GB, Samsung SW-248F, Creative Inspire 4400, Samsung 793MB, Compro PVR/FM, WinLIRC
Laptop: HP Pavilion dv8210us
mod-the-pc is offline
Old 23-03-2007, 08:50 PM   #3 (permalink)
Arsenal_Gunners's Avatar
Just delete the autorun.inf files
Arsenal_Gunners is offline
Old 24-03-2007, 09:56 AM   #4 (permalink)
Ganeshkumar's Avatar
I too had similar problem after removing virus with Norton... So I installed CA Anti virus.. n wat it did is.. It just deleted the file autorun.inf n problem solved...
I think even if we format the drive with FAT32 (Quick) the problem is unsolved.. So if u want to format then dont quick format ..
Ganeshkumar is offline
Old 25-03-2007, 12:44 PM   #5 (permalink)
Pragadheesh's Avatar
Post Re: Drives Not Opening... Help Required....
even 'm having d same prob.... on right clicking a drive , d 1st option s autoplay then search after which there s open....
I tried deleting d autorun.inf file... but still in vain..
when ever i go back to [b]My computer[b] a new auto run.inf file gets created... also there s another file IISDLL.dll.vbs file.... haven't noticed this b4...
also tried,
folder options-->file types tab--> folders -->advanced n set open as the default action... even then d prob persists... help me in solving this prob....
Pragadheesh is offline
Old 25-03-2007, 01:17 PM   #6 (permalink)
error opening my hard drive partition
Scan for adwares and viruses.
Old 25-03-2007, 10:37 PM   #7 (permalink)
An Esoteric Geek
sridatta's Avatar
Ye.. just delete autorun.inf files as vimal said..
if you cant find them.. go to folder options and uncheck.. hide system files and folders option in view..
sridatta is offline
- by Krow
