tarts a new instance of the Alcohol Command launcher
Syntax:
AxCmd [drive:] [/M:[path][filename]] [/u] [/L] [/?] [@cmd]
Usage:
Mount the image file : AxCmd drive: /M
ath [@cmd]
@cmd Execute this file(cmd) after mount file.
Return drive letter when ready, return 1 when failure occure.
Unmount the image file: AxCmd drive: /U
Report command : AxCmd /L
Return the number of virtual devices,
return 0 if there is no virtual devices
Extra Options:
/? display this help and exit
drive: can be A...Z or 1...31
The value of 1...31 means the number of virtual devices
cmd should include full path name, and the extension tparts
In example : AxCmd 1: /M
:dialo2_2.mds @1
LAYD2.EXE
This means that mount D:dialo2_2.mds into first virtual device
and run the PLAYD2.exe in this CD-ROM
