Old 21-03-2007, 06:36 PM   #1 (permalink)
Default imternal tv card picture but no sound
well i bought a internal tv card of gadmei ...well the whole catalog is in chinese
and problem the pictures some fine but no sound
well i have tried..doing sound out of the card to line in of the inbult sound card..
but no help
actually there is country setting ..if i keep other country other than china there is video no sound
if i keep that to china there is sound but no video...
what to do
should i return that card?
be who u r :
Saharika is offline
Old 22-03-2007, 03:26 AM   #2 (permalink)
shantanu's Avatar
Default Re: imternal tv card picture but no sound
you can try to set it manually, det some setting to NTSC/PAL and sound (it is in chinese) then also, you must see some BAND S, or something like that , keep changing it and then see , i think you will get it right....
try to change setting which you,, temper the settings and you will do it,
the last option is to give the card back,
shantanu is offline
Old 22-03-2007, 07:42 AM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
This will help you:
Try inserting the audio input pin in different holes of ur sound card.
Another thing U sud try,if it doesn't work:
You must have got a small wire with ur TV tuner card...just insert its one end into sound card n another into soundcard.You have done.
ravi_9793 is offline
Old 22-03-2007, 10:46 PM   #4 (permalink)
well it is getting serious now..
i even exchanged the card but same problem
i am trying to use that card in piii computer...which has inbuilt sound card...
now i have noticed that in tune ..well if i move the silder of tuning at some point the audio only comes and at some point video only comes ..
but in none of the point both a/v comes...
even we can type frequencies..but how could we know frequencies of all channels..
and the video system is only NTSC_M and is not changeable to others..
well i have tried joining to every possibles holes of the card..but no luck
and these silly chinese ..they sell their hardware here but all catalog is in chinese..
doesnt any body in the country use gadmei internal pci sound card pt307
how it is managed..
well i have found that in this part it is used by none but in market i can see it all around every shop
some body help
http://www.gadmei.com/new3/ProductSh...?ArticleID=139
be who u r :
Saharika is offline
Old 23-03-2007, 01:25 AM   #5 (permalink)
Back to School Mr. Bean !
mod-the-pc's Avatar
Have you tried using a third party software like ChrisTV/WinDVR?
Desktop: P4 2.8E, Intel 865GBF, 512MB Hynix PC3200, Samsung SV1204H 120GB, Samsung SW-248F, Creative Inspire 4400, Samsung 793MB, Compro PVR/FM, WinLIRC
Laptop: HP Pavilion dv8210us
mod-the-pc is offline
Old 23-03-2007, 01:36 AM   #6 (permalink)
hailgautam's Avatar
check the sound out in the settings of your Tv tuner card settings, it happened to mine, that i had given a wrong output for the internal TV tuner card.
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 23-03-2007, 02:31 AM   #7 (permalink)
ya now i did
and that christv is not scanning any channels says 0 channels found...
what might be problem
i have used PAL_B
be who u r :
Saharika is offline
- by Krow
