drives of my pc dnt open by double clicking instead "search" opens .ive to rt click and then select open. also the frst option is search on rt clickin d drive help me out!!
i also set set default value in folder of folder option bt it doesnt wrk.
dude im not sure....but most probably thr mst be a file in ur drive which has specified this autorun cmd....so unhide hidden folders....n delet the file..b carefull....if this helps do let me know
IF THIS HELPS PLEASE CLICK THE BALANCE UNDER MY ID............:wink: 8-)
