Old 19-03-2007, 09:46 PM   #1 (permalink)
Mad and Furious
redhat's Avatar
Question How to extract encrypted files?
I recently formatted my computer. I had encrypted a folder, using Win XP's encryption. But I forgot to decrypt it, before installation. Someone please tell me, how to extract the files from such encrypted folders as they contain very valuable information? Also, does formatting, also erase the my docs folder placed on another partition??
My new Tech Blog : http://technewspaper.blogspot.com/
redhat is offline
Old 20-03-2007, 04:55 PM   #2 (permalink)
aj27july's Avatar
Default Re: How to extract encrypted files?
look in the FAQ section of the software's website
or maybe contact the program's developers through the website.
and next time do not use these stupid programs. Use TRUE-CRYPT. Its free and open source. And you can recover the files(if they are not on c drive) if you format c: as the encrypted files are placed in well protected Safes.
The moment you start looking for the truth,
you are no longer a part of the mob,
you become an individual.
----OSHO
aj27july is offline
Old 20-03-2007, 08:41 PM   #3 (permalink)
Mad and Furious
redhat's Avatar
Post Re: How to extract encrypted files?
I used the inbuilt encryption feature in Windows XP. Not any other program! The encryption feature that prevents your data from being accessed by any other user on that computer. I formatted my drive, now how do I access those folders which I had encrypted before i formatted my drive!
redhat is offline
Old 20-03-2007, 09:43 PM   #4 (permalink)
prasad_den's Avatar
Was your file system NTFS...?? I doubt if you can recover anything worthwhile..!!
prasad_den is offline
Old 21-03-2007, 11:08 AM   #5 (permalink)
Mad and Furious
redhat's Avatar
Yes, my file system was and is till NTFS. No, I did not lose the data in formatting! It was on a different drive, and I had encrypted it. I formatted my system drive, and now im unable to access the encrypted folder from the other drive!
redhat is offline
Old 09-04-2007, 09:22 PM   #6 (permalink)
mohit sharma's Avatar
use software " GetDataback4NTFS " and recover the encrypted folder as like u are recovering portion of hard drive , this software will recover encrypted files as usual normal files
remember this software isn't a freeware and u know what :-P
" :arrow: CONNECTION BETWEEN LIFE AND TECHNOLOGY " is my topic of research !!!!
don't believe and respect any authority with closed eyes other then almighty !!!!! :idea:
mohit sharma is offline
Old 10-04-2007, 10:38 AM   #7 (permalink)
I Always Prefer 1080p
techtronic's Avatar
The inbuilt EFS (Encrypting File System) in Windows XP
requires a Data Recovery Agent to be created for recovery
Also it encrypts using a user's SID and GUID
So if you format your comp after encrypting, u will lose your data as its irrecoverable
techtronic is offline
Old 11-04-2007, 08:30 AM   #8 (permalink)
believe i had recovered it even after formatting , many times , using procedure told above !
- by Krow
