You may like to use Deepfreeze. It will allow installing new programmes or even delete the entire hard disk. But restart the PC and every changes will be gone.
actually my comp. is being exploited for games only... i just want to restrict my frnds to b unable 2 install ny prgrms..restriction will b OK if it is apllies even 4 me
The difference between impossible and possible lies in determination.
100ARAB 9LAKHa((saurabh nolakha))
The best way if you are using Windows XP is to make a "Limited User Account", & with parental control set it to allow only a few applications .exe to run. Now unless someone has administrator password, they can't even double click to install a virus.
thanks a lot dear!!!
