Old 18-03-2007, 03:24 PM   #1 (permalink)
Chetan1991's Avatar
Default Damaged CDs :Pls help!
Hi!
Many of my CDs are developing spots on them or their upper shiny layer worns out a bit.Their size isn't very big ,yet this is making them useless.I think it is because of excessive moisture in the surrounding.What can I do to prevent this? Is there any way I can copy the data of damaged CDs to HDD?
Chetan1991 is offline
Old 18-03-2007, 03:36 PM   #2 (permalink)
No longer here..
Default Re: Damaged CDs :Pls help!
well to prevent the spots forming in the first place you can use cd labels/stickers which are circular and paste them onto cds.what this does is,it forms another layer of protective surface and moisture doesnt come in contact with the shiny layer.
If you have already damaged the cds enough you can try data recovery software like isobuster where in you can copy/extract the contents to a folder of ur choice.Isobuster also allows skipping of non-readable areas.
indian_samosa is offline
Old 18-03-2007, 03:50 PM   #3 (permalink)
Kiran.dks's Avatar
To recover data from the damaged CD's use Isobuster, CDroller or BadCopy.
Kiran Kumar R
Kiran.dks is offline
Old 18-03-2007, 08:33 PM   #4 (permalink)
mekalodu
iinfi's Avatar
hi samosa... plz let me know how much do the cd labels/stickers cost??? where do u get them??
thanks ...
mekalodu
iinfi is offline
Old 18-03-2007, 10:55 PM   #5 (permalink)
No longer here..
the stickers cost .50 paise or so.They are nothing much hi-fi ...just plain labels like how when we were kids we used to put labels with our names on the books..only the labels were rectangular ..these are circular.You will get them probably from local vcd wallas if he stocks blanks cd's along with movies.You will definately get them from vcd wallas who stock pirated movies.. because pirated vcd's require labels to be stuck onto them to display movie names ..
Old 18-03-2007, 11:35 PM   #6 (permalink)
Still Shining!
Lucky_star's Avatar
Wet your hand a little bit and with this touch a CD. Or better, dip a cd in water for some time. After that, keep the CD for a week or two. You will find dots in the shape of a growing fungus appearing on the surface, and will gradually eat up the CD rendering the media useless.
The best way to prevent this is to dry the CD in the sun or under the fan for 5-20 minutes. Then, keep the CD in sealed plastic covers. This prevents the further entry of moisture.
Palms wet with sweat and and oil damages the CD easily.
Nokia N86 8MP
Lucky_star is offline
Old 18-03-2007, 11:40 PM   #7 (permalink)
No longer here..
@lucky_star ..even I have seen fingerprint shaped damage on one of my cds.I guess the sweat must have eaten away the surface.
Old 18-03-2007, 11:57 PM   #8 (permalink)
Still Shining!
Lucky_star's Avatar
Yah, Just do an experiment by making an sweat-oil-combination finger print on the CD and see the changes happening to that spot.
Nokia N86 8MP
Old 19-03-2007, 12:03 AM   #9 (permalink)
Be CoOl rAp RuLeZ !!!
krates's Avatar
Hey Man Use Cd/dvd Data Recovery Software If Not Getting It Anywhere Ask One From Me
iPhone 3G 16GB + Samsung I450 + Sennheiser CXL 400 + PSP Phat + Samsung NC10 :D
Previous phones: N73ME , W810I , Asus P320
krates is offline
Old 19-03-2007, 12:11 AM   #10 (permalink)
Gangsta
Josan's Avatar
Location: I come from the land of WARRIORS, land of 5 rivers, where the alcohol will make your liver quiver!!
No premanent solution for this prob....
Josan is offline
Old 19-03-2007, 10:39 AM   #11 (permalink)
aj27july's Avatar
ya. use cd-dvd data recovery.
google for it.
The moment you start looking for the truth,
you are no longer a part of the mob,
you become an individual.
----OSHO
aj27july is offline
Old 19-03-2007, 11:27 AM   #12 (permalink)
piyush gupta's Avatar
Problem solved by Kiran
see his post
piyush gupta is offline
Old 19-03-2007, 11:37 AM   #13 (permalink)
Welcome To The Jungle
sysfilez's Avatar
try using badcopy pro, its quite helpful.
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
Old 19-03-2007, 12:42 PM   #14 (permalink)
::cyborg::'s Avatar
there was a posst by some guy in this forum search for it
write damaged cd in search box
:)) - KEEP SMILING
::cyborg:: is offline
Old 19-03-2007, 06:14 PM   #15 (permalink)
Chetan1991's Avatar
Thanx guys. I'll try Isobuster .
Dell Inspiron 1564
i3 330M 2.13GHz
4GB DDR3 1066MHz
ATI M.R. HD 5450 1GB
298 GiB 7200rpm WD hdd
LG Optimus One P500
where-go-for-6-week-industrial-training?
Old 20-03-2007, 07:24 AM   #16 (permalink)
mekalodu
iinfi's Avatar
well, wud u stick the stickers on the underside of the CDs????
if yes, how wud the CD drive read the CDs????
mekalodu
iinfi is offline
Old 20-03-2007, 08:40 AM   #17 (permalink)
No longer here..
dude...i am not talking about sticking the labels on the underside..obviously the drive wont be able to read.I am saying sticking the labels on top of the cd where its written moserbaer,sony or whatever.One doesnt need to protect the underside as long as you dont scratch it...since its polycarbonate and doesnt succumb to rust or material degradation.If you read above the original poster's query was ...how to prevent the spots forming which by the way form only on the shiny layer(top layer).I hope now the point is clear.
Old 21-03-2007, 01:04 PM   #18 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
wash the cd in water & freeze it & then try it ............
it really works ............
ax3 is offline
- by Krow
