Old 17-03-2007, 09:32 AM   #1 (permalink)
Default Why i am unable to rename file ?
Whenever i m trying to rename file i m getting following message......
if you change file name extension,file may become unusable.
link....
mkmkmk is offline
Old 17-03-2007, 10:06 AM   #2 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
Default Re: Why i am unable to rename file ?
hey buddy......
You can change the file name but u hv to chnge the settings............
Method1
1.Go to Tools>Folder Options>View tab
2.In the View Tab Option.....
Check The Option
Hide Extensions For Know File Type.........
3.
Apply it and change the file Name............
Method2
If u dont want to change the settings then .........
1.Rename The File with given way
FileName.Extension
For Example
Tochange the file name Ron.doc to 1991.doc
thenRename it as 1991.doc
||uLtiMaTE WinNER||
Ron is offline
Old 17-03-2007, 10:49 AM   #3 (permalink)
Thanks Ron, method 1 worked perfectly......thanku very much .....
mkmkmk is offline
Old 17-03-2007, 11:22 AM   #4 (permalink)
Mad and Furious
redhat's Avatar
Thumbs up Re: Why i am unable to rename file ?
But the second method is what u should be using.
I personally prefer that method, with the file extentions showing, because type conversion, sometimes helps in opening files
My new Tech Blog : http://technewspaper.blogspot.com/
redhat is offline
- by Krow
