Old 14-03-2007, 06:49 PM   #1 (permalink)
Default Need help urgently
Hi all,
I am running a jewellery shop and wish to prepare a biling software which can automatically sum up the /gram, quantity and unit sold. For example if i sell jewellery which is 10 gram (1tola) the price should add up at the current prevailing rate in market also there should be gram section. I am facing a bit if problem in putting this question in words but expect some help. Thanx
muks.max is offline
Old 14-03-2007, 06:52 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Need help urgently
contact any professional programmer... and tell him to make a soft for u...
or try rentacoder.com
Pathik is offline
Old 14-03-2007, 07:27 PM   #3 (permalink)
24online's Avatar
Lightbulb Re: Need help urgently
soft. possible... check download.com or softpedia.com
check , i found...
http://www.softpedia.com/progScreens...hot-33460.html
or ask programmer to make program for shop with ur requirement....
**#(o)#**
24online is offline
Old 14-03-2007, 07:51 PM   #4 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
I would suggest to checkout Google and Sourceforge.net for free billing softwares.
If you can spend some money...i wont suggest to get it coded. Since it will be expensive and lack features. There are plenty of Paid and good Billing softwares out there full of features
Download a few DEMO and checkout if it works for you
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 14-03-2007, 08:05 PM   #5 (permalink)
a_g = JPKN
s18000rpm's Avatar
The way to keep up to date accounts without any tension. It is useful accounting software for Jewelry Business as Gold, Silver, Un-Tensil Merchant, Gold and Diamond Showroom. This software helps into handling the stock of old and new Gold & Silver and Jadau & Simple Ornaments of these Mattel and Un-tensil.
Jewelry Accounting with Billing Software 3.6
HomePage :www.pelagiansoftwares.com
Shareware : Cost $120
Source:: First result in Google Search
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 14-03-2007, 08:06 PM   #6 (permalink)
Ganeshkumar's Avatar
For a good Software specially made for u...
Get help frm some programers...
Ganeshkumar is offline
- by Krow
