Old 14-03-2007, 01:29 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Hide links in webpages ! ! !
wanna hide links in webpages using css ?
when mouse over & out ........
dont wanna display links on mouse events ........
ax3 is offline
Old 14-03-2007, 01:51 PM   #2 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Default Re: Hide links in webpages ! ! !
Are you looking for Tooltips with links on mouse over ?
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 14-03-2007, 04:13 PM   #3 (permalink)
ax3
ax3's Avatar
if v put mouse over any link ........ its path is displayed @ the bottom of ur browser .......
wanna avoid that ..........
ax3 is offline
Old 14-03-2007, 06:14 PM   #4 (permalink)
Host4Cheap.org
You can use this if you want to do it for single link
<a href="#" onClick="window.open('URL');return false">TEXT</a>
Or put this code in <HEAD></HEAD>
<script>
function hidestatus(){
window.status=''
return true
if (document.layers)
document.captureEvents(Event.MOUSEOVER | Event.MOUSEOUT)
document.onmouseover=hidestatus
document.onmouseout=hidestatus
</script>
Old 15-03-2007, 11:30 AM   #5 (permalink)
ax3
ax3's Avatar
@sukhdeepsinghkohli ........ thanx ...... will + in webpg .........
ax3 is offline
- by Krow
