Old 30-01-2005, 01:16 PM   #1 (permalink)
Default UNDERGROUND 2 MUSIC
How do i capture nfs u 2 music . i tried using snagit screen capture but it didnt work .Secondly i tried Camtasia studio but this time the audio was not clear ... which software should i use to capture audio from nfs u without a lose in audio quality
vijaythefool is offline
Old 30-01-2005, 01:45 PM   #2 (permalink)
Try this buddy..
http://dl.filekicker.com/send/file/1...orderSetup.exe
or do a google search as "Total Sound Recorder"
..::The Slam Team::..
Slam Team is offline
Old 30-01-2005, 03:13 PM   #3 (permalink)
i tried it but didnt work
Old 30-01-2005, 10:42 PM   #4 (permalink)
harmax's Avatar
ahhhmm
there r always softwares that rip ( convert rather ) the soundtracks of these games to WAV files . i dont know the legality of doin that . but i can tell u U HAVE CRACKS FOR IT and i could rip the songs for nfsu1 but never tried for nfsu2
am not goin to give u any links for it cause the RULE SAYS.........<<>>
any google it i am sure ull fin it .... ( cause i found it !!!!)
harmax is offline
Old 31-01-2005, 10:38 AM   #5 (permalink)
Did u use crack for it ! dont u know u have done some thing illegal !
Old 31-01-2005, 01:00 PM   #6 (permalink)
club_pranay's Avatar
is there any way to add tracks to the playlist in the game?
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 31-01-2005, 05:47 PM   #7 (permalink)
well for the time being play winamp in the backgound
Old 31-01-2005, 11:11 PM   #8 (permalink)
harmax's Avatar
i donno!!!!!!!!1111
harmax is offline
Old 01-02-2005, 06:59 PM   #9 (permalink)
i got the music using nero sound trax but the sound isnt clear how can i correct this
Old 01-02-2005, 07:52 PM   #10 (permalink)
vysakh's Avatar
use audacity for recording
Incompatible message format
vysakh is offline
Old 01-02-2005, 11:17 PM   #11 (permalink)
A Year Closer To Heaven
ctrl_alt_del's Avatar
Run a google for it and I am sure you will get the desired links. I cant give them to you coz that will result in a banw hich I can do without.
ctrl_alt_del is offline
Old 02-02-2005, 12:45 AM   #12 (permalink)
svk
i was goin to tell u the same. try sites thre u'll find it in mp3 format.
svk is offline
- by Krow
