Old 13-03-2007, 01:04 PM   #1 (permalink)
Mad and Furious
redhat's Avatar
Smile how to execute an exe file from Visual Basic 6.0
Hi friends,
I am making a progam in VB. I need to execute an exe application that I made in VB. I need to execute it since, adding the source for 10 apps into one, is very difficult and will hog system memory. So, I want to know how to execute an exe file from an app made in VB 6.0. I am not very familiar with API's, but if you tell me the process, I will easily understand it.
Thank You in advance
My new Tech Blog : http://technewspaper.blogspot.com/
redhat is offline
Old 13-03-2007, 02:32 PM   #2 (permalink)
The Unknown's Avatar
Default Re: how to execute an exe file from Visual Basic 6.0
Originally Posted by redhat
Hi friends,
Wait for some VB ppl. And ur name is redhat but ur logo is not redhat!
KDE on ArchLinux
The Unknown is offline
Old 14-03-2007, 10:20 AM   #3 (permalink)
Hey friend tell me which type of project you want to make. Post here so that I can easily help you.
abhijangda is offline
Old 14-03-2007, 10:35 AM   #4 (permalink)
Mad and Furious
redhat's Avatar
Smile Re: how to execute an exe file from Visual Basic 6.0
I want to execute a particular exe file when the user selects an option from the menu. These are just add-ons and are not related to the program itself.
redhat is offline
Old 14-03-2007, 10:44 AM   #5 (permalink)
Kiran.dks's Avatar
Hi friends,
Simple. Execute the exe file directly from Command line. Use shell or ShellExecute. See that you give the exact location of the exe.
Kiran Kumar R
Kiran.dks is offline
Old 14-03-2007, 11:12 AM   #6 (permalink)
Hope this helps: http://www.dreamincode.net/code/snippet276.htm
Arun
sakumar79 is offline
Old 17-03-2007, 02:28 PM   #7 (permalink)
Mad and Furious
redhat's Avatar
Arun
Thanks a lot,
It worked well for me
__________
Hi!
I am having a problem in using the "%Systemroot%" to refer to the "C"\Windows" directory.
I used to following code as suggested by sakumar79:
Dim RetVal
RetVal = Shell("%Systemroot%\System32\calc.exe", 1)
Please tell me where am I wring???
redhat is offline
Old 17-03-2007, 05:24 PM   #8 (permalink)
Try
Dim RetVal
RetVal = Shell(""%Systemroot%\System32\calc.exe"", 1)
Or
Dim winPath as string
Dim RetVal
winPath = Environ$("SystemRoot")
RetVal = Shell(winPath & "\System32\calc.exe"", 1)
Arun
Old 17-03-2007, 06:32 PM   #9 (permalink)
Mad and Furious
redhat's Avatar
Thumbs up Re: how to execute an exe file from Visual Basic 6.0
Thanks a lot sakumar79
redhat is offline
- by Krow
