Old 30-01-2005, 07:20 AM   #1 (permalink)
The pWnster
Vyasram's Avatar
Default My pc crashes frequently
Since i reinstalled everything after a virus attack, my pc has been acting strangely I restarts automatically without any warning and it also hard reboots sometimes .When i log into the internet the monitor shows grains of a different pattern each type and everything strucks and i have to hard reboot it again. This problem gets more severe when i install any antivirus suite .It also doesn't allow me to update anything. My system is a Hp havilion 8851 with P3 866,20gb hdd and 192 mb ram. I connect to internet using dial-up and i use winxp.
Please tell me what is the problem and how can i cure it
Vyasram is offline
Old 30-01-2005, 09:42 AM   #2 (permalink)
Default Format
if u have used repair function of WINDOWS, i think u must perform a full format and not a quick format. if u did format, then uninstall the device drivers and then re-install them. or try installling an antivirus in safe mode and then perform a full system scan in safe mode only. Also check for any unwanted processes and also check for any spywares. Think this should help.
Shwetanshu Srivastava
shwetanshu is offline
Old 30-01-2005, 12:31 PM   #3 (permalink)
First run an uptodate antivirus scan, and a spyware scan and reeistry mechanics to find all those criminals causing ur system to crash.
Use the PC for 2-3 days to see of everything is fine.
If not then do a Windows reinstall where u format ur HDD. Without which a reinstall is useless.
Have a Nice Day :)
Mohammed Muchhala, © 2006, All Rights Reserved
http://www.muchhalasworld.com
babumuchhala is offline
Old 30-01-2005, 02:16 PM   #4 (permalink)
Telltale signs of a RAM problem. First, goto your BIOS and set ur system to default factory settings. Run XP in safe mode and see if it reoccurs.
DON\'T waste money on expensive ipods. Simply think of your favourite tune and hum it. If you want to \"switch tracks\", simply think of another song you like and hum that instead.
gamefreak14 is offline
