Hi Guys,
1)I have Windows XP Home Edition(SP2). I did defragment and the result is as follows.
It says that " Files that cannot be defragmented showing the files".How to correct it?
Volume (C
Volume size = 19.52 GB
Cluster size = 16 KB
Used space = 4.31 GB
Free space = 15.22 GB
Percent free space = 77 %
Volume fragmentation
Total fragmentation = 0 %
File fragmentation = 0 %
Free space fragmentation = 0 %
File fragmentation
Total files = 20,595
Average file size = 146 KB
Total fragmented files = 3
Total excess fragments = 8
Average fragments per file = 1.00
Pagefile fragmentation
Pagefile size = 744 MB
Total fragments = 91
Folder fragmentation
Total folders = 2,250
Fragmented folders = 11
Excess folder fragments = 21
Fragments File Size Files that cannot be defragmented
2 136 KB \WINDOWS\SYSTEM32\DRIVERS\Hdaudbus.sys
7 3 MB \Documents and Settings\CHANDRAKUMAR.S\Local Settings\
Application Data\IconCache.db
2) I have got AVG FREE EDITION. The version is 7.5.432. After running the scanning each time,
the reult comes as follows. How to correct it?
OBJECT RESULT STATUS
C:\WINDOWS\System32\user32.dll Change Changed
C:\WINDOWS\System32\Shell32.dll Change Changed
C:\WINDOWS\System32\ntoskrnl.exe Change Changed
3) What is the simple method to do Chkdsk?
