1)Right click on the file for which u want the password to b put.
2)Click on "Add to Archive".
3)Then go to Advanced tab.
4)Click on set password...choose ny passwd.
5)Click ok.
6)A winrar file with ur filename will be created.
Also, if you want the password prompt to take place before the window opens, means if you want the user to be not able to c the filenames without entering a password, in the password option window, choose encrypt filenames
