My Webpage loads contents, images, animations, etc, correctly, only if user has 1024 X 768 or above Screen Resolution. But if user has below 1024x786 screen resolution, the page looks pretty horrible
Can anyone reply me with a javascript, that I will include with my webpage, that will redirect user to another page, if his screen resolution is below 1024 X 768 Screen Resolution, as just in the case of Yahoo! Mail Beta.
__________
Example:
Just head to
https://login.yahoo.com/config/login_verify2?&.src=ym an enter your username and password >
http://aa.f584.mail.yahoo.com/dc/lau...3h46eghs9tygh3
If you are having the screen resolution below 1024 X 768, you will be redirected to
http://aa.f584.mail.yahoo.com/dc/sys...on=unsupported , telling you that; Seems your screen resolution is set below our minimum recommendation. When it's set under 1024 x 768 pixels, Yahoo! Mail Beta looks pretty horrible.
Please reply with the javascript, the will do this work.
