Old 11-03-2007, 03:34 PM   #1 (permalink)
amit2005's Avatar
Default Retrieving Firmware
any body knowing the method of retrieving firmware from MT882 modem cud plzz post it cuz i screwed up the firmware of my MT882 to Mt880..no help by resetting ..only way is to upgrade to MT882 firmware..if any body have it plzz post it...my fren has MT882 n i cud retrieve firmware from him
P.S. other links mention in forum for MT882 firmware r not working..{even changing file name from .bin to .xdsl} ..+ no help from other modem tweaking thread on this forum.
__________
seems like nobody is knowing nothing
ROCK IS HERE
amit2005 is offline
Old 11-03-2007, 06:59 PM   #2 (permalink)
prasad_den's Avatar
Default Re: Retrieving Firmware
@amit: You need to wait for some time before you see responses to your questions..!! And why do you want to start a new thread always.. You would get better response if you continued in the same thread..!
BTW, I remember that the link I gave you also had the original old firmware for the MT 882.. What happened to that?
@The Unknown: You are spamming the forum with useless posts..!
prasad_den is offline
Old 11-03-2007, 08:34 PM   #3 (permalink)
The Unknown's Avatar
deleted. i was not spamming. i did dat cozz.. i understood purely NOTHING.
KDE on ArchLinux
The Unknown is offline
Old 12-03-2007, 08:25 AM   #4 (permalink)
amit2005's Avatar
that thread is on page 4 when i last checked.....
n the firmware didn't work it says invalid file upgrade
ROCK IS HERE
amit2005 is offline
