Old 29-01-2005, 03:52 PM   #1 (permalink)
Default low level formatting
can any one tell me how to do low level formating
zuhaib is offline
Old 29-01-2005, 05:55 PM   #2 (permalink)
Low-level formatting is very stressful to the hard disk. Therefore, modern hard disks are usually protected from casual low-level format such as the low-level format option in BIOS. They may appear to accept the low-level format command, but will not actually do so.
For those times when a hard disk must be low-level formatted, the manufacturer usually has a downloadable tool on their website.
pimpom is offline
Old 29-01-2005, 07:54 PM   #3 (permalink)
tuxfan's Avatar
You can use a software for this. I have one DOS based software called ZTEST. PM me and give me your email address. I will mail it to you.
tuxfan is offline
Old 29-01-2005, 09:41 PM   #4 (permalink)
get spinrite
all other poitns have been covered by pimpom
No Mercy, No Limits.
theraven is offline
