I have got Samsung 17" Monitor. But a software on my computer shows 15" instead of 17". Where can I view the size of my monitor and how to correct it? I am using Windows XP Home Edition.
see the model number and the make of the monitor and search on the manufacturer and see the specs there.
If u r damn sure abt the moniter size ..than why u belive on softwares.Not always the software are correct or very helpfu.Use your own mind also smtime.
Wht you think that..if sofware is saying that ur moniter is 14"..than ur 17" moniter will become 14".
And if the sofware says mine 17" moniter is 19"..than will it become 19".......LOL
