Old 09-03-2007, 06:31 PM   #1 (permalink)
Default my mtnl speed is down
i m(thane) using DSL-NU plan but from last two days at night my speed is decrese from 30 KBps to 17 KBps whats the problem DID ANYBODY FACING SAME ROBLEM
agasti is offline
Old 09-03-2007, 06:56 PM   #2 (permalink)
Security Exp
47shailesh's Avatar
Default Re: my mtnl speed is down
if you want to discuss this than post in chit chat section...
or if you r so confident that ur sys is screwed uo than post ur HT log here
We Love Once, And When We do We do it Well
47shailesh is offline
Old 09-03-2007, 07:06 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
^^^..call customer care....it may be some technical problem.
ravi_9793 is offline
Old 09-03-2007, 07:49 PM   #4 (permalink)
The Unknown's Avatar
my cousin lives in powai. he's facing the same prob.
KDE on ArchLinux
The Unknown is offline
Old 09-03-2007, 07:50 PM   #5 (permalink)
Still in war with allies
ssdivisiongermany1933's Avatar
MY speed is down from 30 KBps to 25KBps for past 1 month
ssdivisiongermany1933 is offline
Old 09-03-2007, 08:10 PM   #6 (permalink)
ApoorvKhatreja's Avatar
Yes, lots of people, who were earlier synced to 288 Kbps, have now been synced to 256 Kbps. Moreover, alot of unlimited plan users were mistakenly given 2 Mbps speed, which has created a great load on the MTNL infrastructure, and thus the SNR Margins these days are quite bad, resulting in low speeds.
http://apoorvkhatreja.blogspot.com
ApoorvKhatreja is offline
Old 09-03-2007, 08:41 PM   #7 (permalink)
they 're talking abt dialup!
KDE on ArchLinux
Old 09-03-2007, 08:45 PM   #8 (permalink)
No they aren't. He mentioned DSL-NU in his post. Check it out. Moreover, nobody gets 30 KBps in dialup .
Old 10-03-2007, 10:48 PM   #9 (permalink)
Tux Fan
shaunak's Avatar
30KBps on dialup!
A quick explanation:
KBps = kilo bytes per second
Kbps= kilo bits per second
One byte = eight bits.
Thus: 256Kbps = ( 256/8 )KBps = 32KBps
[which is the minimum data transfer rate for a connection to be called "broadband" ]
Similarly: 56Kbps = 7KBps
[Maximum data transfer rate for dial up.]
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 11-03-2007, 11:03 AM   #10 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
TRY calling 1504 ......... hope they pick it up & not put u on "KAATAR" .......
else find from a nearby triband user abt the connectivity ..........
ax3 is offline
