Old 09-03-2007, 03:22 PM   #1 (permalink)
The Devil's Advocate
iMav's Avatar
Default The new iTunes 7.1
(1) Full-Screen Cover Flow
(2) Support for Apple TV
(3) Other Updated Preferences Tabs
(4) New Categorization Options
(5) Indications of Unwatched Video Content
(6) Secrets? Text strings within iTunes 7.1 suggest several previously unknown details about Apple TV. First, there is apparently a limit of five Apple TVs synchronized to one computer with iTunes. Additionally, there’s an unusual iTunes message warning that “All existing games on the Apple TV (name) will be replaced with games from this iTunes library.” Before you get too excited about that discovery, we also noticed similar references to Nike + iPod and Voice Memos on Apple TV as well - strings of text that may never be used by the program, and simply be duplicates of synchronization messages that pop up when an iPod or iPod nano is connected. As always, we’ll have to wait and see what Apple actually does in the future.
and the best that i felt was:
(7) Colored iPod shuffle Icons: iTunes now correctly identifies the color of an aluminum second-generation iPod shuffle under the Library and Settings menus.
More info with images Click Here
Download
http://beingmanan.com
iMav is offline
Old 09-03-2007, 03:46 PM   #2 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Default Re: The new iTunes 7.1
Thnx for the update
rakeshishere is offline
Old 09-03-2007, 07:03 PM   #3 (permalink)
You gave been GXified
gxsaurav's Avatar
Just used the so called Vista compatible iTunes 7.1. Whats wrong with Apple, 40 MB RAM usage while playing a M4A file.
The new close-max-min button are Like Vista when installed on Windows Vista. They glow. Why can't Apple use WPF to create the UI now.
Since I don't have an iPod, I can't check iPod connectivity in Windows Vista.Wish it would work with my K750i as it also plays m4a. Right now using a WMP hack to sync m4a to memory card
about.me/gxsaurav
gxsaurav is offline
