View Poll Results: how was the solution
simple and good 1 100.00%
simple 0 0%
better 0 0%
Voters: 1. You may not vote on this poll
Old 29-01-2005, 04:20 AM   #1 (permalink)
Default blaster worm
a blaster worm in win2003 is jst similar to that of the sassar which was caused to win xp.it gives a similar one minute timer on connection to internet and a msg inluding REMOTE PROCEDURE CALL error .A simple and better way instead of formatting the drive or booting into CMOS settings can b avoided by jst going to taskbar and then in processes ,click on images to arrange them in alphabet order and in last delete the MSBLAST.EXE file from it.u can over cme with it by jst moving to windows security in www.microsoft.com n then installing a package against this worm
zuhaib is offline
Old 29-01-2005, 04:33 AM   #2 (permalink)
an even better way is to have a good, updated antivirus and updated windows which will prevent the blaster worm frm infecting ur computer....
Nemesis is offline
Old 29-01-2005, 02:19 PM   #3 (permalink)
also the blaster worm exists for win xp as well
first of all u need to goto start=> run and type in shutdown -a to prevent the shutdown
then u need to get the appropriate fix or the stinger from symantec and run it
and this would only happen now if ur careless enuff to not have any updates
blaster is extremely old ant it would be irresponsible on anyones part to not have a fix for it
No Mercy, No Limits.
theraven is offline
Old 29-01-2005, 03:45 PM   #4 (permalink)
Default re blast
another way to avoid is by jst going to taskbar and then in processes ,click on images to arrange them in alphabet order and in last delete the MSBLAST.EXE file from it
zuhaib is offline
Old 29-01-2005, 09:32 PM   #5 (permalink)
dude now ur just being redundant
but seriously whats tur point ? i still dun get why u posted this ?
theraven is offline
Old 29-01-2005, 11:39 PM   #6 (permalink)
Would have helped , a long time ago.
Do I really need a signature to be unique?
allindrome is offline
Old 29-01-2005, 11:56 PM   #7 (permalink)
Default Re: re blast
wait a minute...taskbar???? its task manager not task bar....and u havent even said that CTRL+ALT+DEL brings up the task manager
Nemesis is offline
