Old 08-03-2007, 09:35 AM   #1 (permalink)
Default Iso help
I have an win xp iso file how can i install it without writing it on the cd ?
aditya169 is offline
Old 08-03-2007, 09:40 AM   #2 (permalink)
Default Re: Iso help
If you plan to do this by dual boot, it can be done by first installing another OS and then mounting the ISO on a virtual CD drive using emulators such as Alcohol 120%, etc... But if you want to a fresh install or reinstall etc, you need to burn a CD and then install from it...
Arun
sakumar79 is offline
Old 08-03-2007, 09:40 AM   #3 (permalink)
first of all IMO u can do this only if u r using windows 98 or something.
use free tools like daemon tools, install it, and mount the image onto a virtual drive and install it.
tell me if this was of any help to u
varunprabhakar is offline
Old 08-03-2007, 10:04 AM   #4 (permalink)
aj27july's Avatar
ya
use daemon tools if u already have an installed windows 98/ME version already
The moment you start looking for the truth,
you are no longer a part of the mob,
you become an individual.
----OSHO
aj27july is offline
Old 08-03-2007, 10:28 AM   #5 (permalink)
sorry its not xp its vista iso.,...
and i need to fresh install it,not update previous OS.
so is there any other way?
and 2nd ly is there cds which cab store 800mbs?
__________
can virtual cd work in dos?
Old 08-03-2007, 10:51 AM   #6 (permalink)
no virtual cd doesnt work in dos.
i think moser baer has 800 mb cds.
Old 08-03-2007, 01:19 PM   #7 (permalink)
dOm1naTOr's Avatar
Try copying the Contents to HDD by inserting on deamon tools.
Start setup from ur previous os and select fresh install and after restart the setup will read files from the disc backup copied on HDD.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 08-03-2007, 02:08 PM   #8 (permalink)
gooby pls
Third Eye's Avatar
Mount the iso image file in Daemon tools.
Third Eye is offline
Old 08-03-2007, 04:26 PM   #9 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
USE ALCOHOL 120 and Mount the iso image in the virtual drive and install through it
rakeshishere is offline
Old 08-03-2007, 05:45 PM   #10 (permalink)
!FREEWARES!
Akshay's Avatar
Is d ISO legal? Coz mods wont allow help on illegal stuff...
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 08-03-2007, 05:57 PM   #11 (permalink)
Google Bot
Pathik's Avatar
ISOs r not illegal if u intend to use it personally and u possess the original...
wich i dont think applies to this case...
Pathik is offline
Old 09-03-2007, 09:13 AM   #12 (permalink)
ok i tried it
it says not a valid win 32 application
Old 09-03-2007, 10:33 AM   #13 (permalink)
hailgautam's Avatar
I smell fish here............seems like are Pirates around.....
what you guys are trying to do!!!
Reported.
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 09-03-2007, 11:40 AM   #14 (permalink)
gooby pls
Third Eye's Avatar
ok i tried it
First tell us whether the iso image is real or p-rated?
