Hi Guys,
*I am using CCleaner, the version of which is V1.31.325.When I scan using the ISSUES option Tap, there seem to be
MANY Files under which there are two Taps one is named as Scan for Issues and another is named as Fix selected
Issues. I do not KNOW actually what I should do further. Can you explain them in detail,Sir? Moreover, I would like to delete
completely all files not necessary except all the ones relating operating systems. How to do it? Is there any possiblity
of storing files,at any place automatically or manually,that I delete them all.
*I have got Quick Time Player.Its version is 7.0.4. I would like to have very good sharpness of quality of sound.
Then how to change the settings to get such an effect of sound of sharpness?
*What is meant by BIOS? Does it belong to Operating System or Motherboard? I would like to get familiar with BIOS.
Can you give me some information about from where can I get all the details in this regard? I have got Windows XP Home Edition(SP2) and DG965RY on my computer.
