Start Menu->Run->typr regedit and press enter->HKEY_LOCAL_MACHINE->SOFTWARE->Microsoft->Windows->Current Version->Run
(I think thats it, if I remember right! )
There is no other direct command to get the list of your startup items as in XP.
Here you'll be able to see the start up list of your PC. Delete the value if you don't want it on you start up list. But be careful, if you remove
some important value without knowing its use properly, it might crash your machine. And do back up the registry before trying anything!
Hard work never killed anybody..........But why take the RISK
