Old 28-01-2005, 01:33 PM   #1 (permalink)
Yoda's Avatar
Default Unable to save webpages in some websites ??? help needed
Hi,
I'm unable to save webpages in some websites.
For Eg: in this website i'm unable to save the webpages "h**p://www.espnstar.com"
sometimes even in "h**p://www.thinkdigit.com/forum" website it happens.
but some websites i'm able to save without any hassle.
usually i got to File-->SaveAs and give a name or there will be a Default name.
why it happens and whats the problem. Any solution to rectify this problem.
Thanx in Advance
Arsenal.
Yoda is offline
Old 28-01-2005, 02:15 PM   #2 (permalink)
kl_ravi's Avatar
Some web pages might be protected from being copied. Just disable active scripting in Tools >Internet Options > Security > Custom Level of internet explorer and try again.
Alternatively try to save the webpage in *.mht format. You need to have winMHT installed on your PC. search for WinMHT in google for download links.
But if you want to save the contents, I suggest you to download Jaws PDF Creator form this link below...
http://www.pdfsoftware.com/assets/Ja...torEn_v3.6.exe
It will install as a printer and next time you want to save the page, just choose Print and choose Jaws PDF creator as the printer. It will create a PDF file for you. Which would be easy to manage.
One more thing.... keeping so many applications running (SEE SYSTEM TRAY ... ) and so many windows open might slowdown your PC.
Everything that follows is a result of what you see here...!!!
kl_ravi is offline
Old 28-01-2005, 05:18 PM   #3 (permalink)
Yoda's Avatar
Thanx "kl_ravi" i will try it.
Yoda is offline
