Old 28-01-2005, 01:11 PM   #1 (permalink)
kunwar's Avatar
Default when i installed conflict desert storm 2
i got am error
Component Transfer Error
File Group:app Executables
File:G:\data2.cab
Error:Incorrect function
please help me
help
kunwar is offline
Old 28-01-2005, 01:51 PM   #2 (permalink)
swatkat's Avatar
Default Re: when i installed conflict desert storm 2
Originally Posted by kunwar
i got am error
File:G:\data2.cab
please help me
help
That data2.cab file is not readable....if u r installing it from CD, check if it has any bad scractches.....try copying the whole CD (if u are installing it from CD) to ur computer, either by taking image using for example Nero or by simply copying all filesin CD to ur comp. , then install the software.
http://swatrant.blogspot.com/
swatkat is offline
Old 29-01-2005, 10:44 AM   #3 (permalink)
kunwar's Avatar
please explain me the last line of your reply
please
kunwar is offline
Old 29-01-2005, 12:39 PM   #4 (permalink)
swatkat's Avatar
please
u r installing Desert Storm 2, and it gives .cab file transfer error.it may be due to a badly scratched CD.
Create an image file (.iso file) of the CD using ISOBuster.
http://www.smart-projects.net/isobuster/
OR
Make an image of the CD usin Nero,follow the steps:-
In Nero,Go to Recorder>Choose Recorder, there choose Image Recorder.
Then put ur CD to the drive and with this CD as source make the image file.
http://www.nero.com/us/Nero_6_Ultra_..._A_Glance.html
After creating image file,using Nero ImageDrive (Software bundled with Nero), Run the image file in this Image Drive and then install the game.
swatkat is offline
