10-08-2004, 09:43 PM
I WANT MORE FPS!!
How to tell the contents of an .iso file.
I tried open medkit.iso It opened in roxio CD creator basic. I can't see the contents what I am going to burn. Is there any software to tell the contents of an iso image. Any freeware not trial software like nero virtual cd mounterwhich doesn't work for more than 30 days.
10-08-2004, 11:31 PM
You can use Isobuster BTW its not a freeware. I wont tell you how to keep it working after the trial period because I use only full(paid) versions
10-08-2004, 11:33 PM
NOT Logged out for ever (well certainly) ;)
10-08-2004, 11:55 PM
Winrar can also view/extract iso files
~Therez a difference between knowing the path and walking the path ~
11-08-2004, 12:27 AM
anusoni is right winrar is gudone
11-08-2004, 01:15 AM
Go Through WinRAR ...!!
Easy Available...!!!!!
Have A Nice Day....!!
11-08-2004, 09:17 AM
1 aadi + 1 aadi = 1 full ;)
11-08-2004, 09:31 AM
Isobuster is freeware,Right?
As you enter this life,I pray you depart
With a wrinkled face,And a brand new heart.
-- U2\'s Love and Peace or Else (HTDAAB)
11-08-2004, 10:05 AM
It Works in two modes, the free mode which has limited functionality and and shareware mode which ofcourse needs to be registered after a while.
IsoBuster is part Freeware and part Shareware.
What does this mean ?
goto http://www.smart-projects.net/isobuster/
11-08-2004, 01:23 PM
Hey i use isobuster freeware(very old).It works perfectly on any iso files.It reads the contents and can also extract them individually
The WaNNaB GeeK iNHOUSe
11-08-2004, 01:33 PM
Winrar or Alcohol 120% or WinISO ........
www.techenclave.com Ecumenical Technology !:)
11-08-2004, 02:46 PM
Win ISO or Isobuster, I use both and they both work fine for me. If u need to edit the .iso then u wud need Win ISO, i found that much easier, else Isobuster should do the trick
Walk on the Wild Side. The other side SUX!!!
11-08-2004, 06:37 PM
WinRAR is good.
Simple things are to simple too understand.
11-08-2004, 06:44 PM
ultraISO
use it to edit the .iso's too !!
works for me !
No Mercy, No Limits.
11-08-2004, 07:54 PM
i've burnt that medkit cd. Actually whats the use of that cd??
Thanks & Regards
Pravin Jadhav
11-08-2004, 10:13 PM
Daemon tools is good if you want to make a virutal cd out of the ISO.
if you just wanna see the contents use Win Iso or Winrar.
Saud
12-08-2004, 06:28 AM
The Photoshop Guy
Winrar!!!! Winrar!!!! and only Winrar
..:: peace ::..
Jeba
12-08-2004, 07:58 AM
Use winrar , its free and works perfectly.
;) ~~EiNsTeIn~~ ;)
http://www.tejuspratap.co.cc
12-08-2004, 08:54 AM
#19 (permalink)
winrar is NOT free, its shareware, u have to pay for it after using it for a while.
12-08-2004, 10:26 AM
#20 (permalink)
Davislav Ivanuiz!!!
Use Isobuster. It can open almost all types of CD image files (iso, img etc.).
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
13-08-2004, 05:38 PM
#21 (permalink)
I WANT MORE FPS!!
I have full version of latest winrar 3.30. I try that
E8500+Asus P5Q Pro, GTX280 OC, 4GB RAM+RAID0 2*WD 500GB, CM690+Corsair 650TX, Razer Diamondback+Goliathus Control Edition Omega, Microsoft Natural Ergonomic 4000, Dell E228WFP, X-Fi Titanium+T6060
Search this Thread |
