Old 05-03-2007, 03:17 PM   #1 (permalink)
Default how do u know if anyone has installed keylogger
Hi,
Is there anyway to know keylogger installed on my pc?
I have heard that using keylogger anyone can get my passwords etc.
My system is used my many people in my absence. Is there anyway to know if they have installed any such software.
Thanks in advance.
rajesh_nk22 is offline
Old 05-03-2007, 03:22 PM   #2 (permalink)
Security Exp
47shailesh's Avatar
Default Re: how do u know if anyone has installed keylogger
Set Poilcies to disable install on ur PC..
Create Local User account for other user...
Use a good AV like KAV.. they automatically detect keyloggers....and interup the install..
Else ur r ******.
We Love Once, And When We do We do it Well
47shailesh is offline
Old 05-03-2007, 03:23 PM   #3 (permalink)
Ankur Mittal's Avatar
Just look in the ADD or Remove programs and if found their than it is installed otherwise not.
http://ankurmittal.com
http://ankurmittal.net
Ankur Mittal is offline
Old 05-03-2007, 04:29 PM   #4 (permalink)
whoopy_whale's Avatar
Or try any keylogger removal tools...
Antispy
Elite Antikeylogger
In just two days, tomorrow will be yesterday.
whoopy_whale is offline
Old 05-03-2007, 04:53 PM   #5 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Crtl+Alt+Del... check out the processes list for suspicious ones
koolbluez is offline
Old 05-03-2007, 07:38 PM   #6 (permalink)
Security Exp
47shailesh's Avatar
Dude i would not call a keylogger a good one if it leave it entries in ADD or Remove programs
Originally Posted by koolbluez
Crtl+Alt+Del... check out the processes list for suspicious ones.
Days gone when Crtl+Alt+Del shows all running progs.. now key loggers like Perfect KeyLogger are purely invisible...
You have to use tools listed to detect Perfect KeyLogger...
Pro User: X-Cleaner
IM - P2P Security Appliance: RTGuardian
Regulatory Compliance: Greynet Enterprise Manager
Old 05-03-2007, 10:03 PM   #7 (permalink)
use ProcessExplorerN...it shows all process.
ismart is offline
Old 05-03-2007, 10:17 PM   #8 (permalink)
Security Exp
47shailesh's Avatar
http://www.ardamax.com/keylogger/
Invisible mode makes it absolutely invisible to anyone. Ardamax Keylogger is not visible in the task bar, system tray, Windows 98/2000/XP/2003/Vista Task Manager, process viewers (Process Explorer, WinTasks etc.), Start Menu and Windows Startup list.
Old 06-03-2007, 03:50 PM   #9 (permalink)
aj27july's Avatar
i think you just want to know whether a key logger is running or not!
download KILLPROCESS. it shows you all the current running processes (even those which Windows Task Manager does not show. You can kill the process through KILLPROCESS.
The moment you start looking for the truth,
you are no longer a part of the mob,
you become an individual.
----OSHO
aj27july is offline
Old 06-03-2007, 04:58 PM   #10 (permalink)
Maverick340's Avatar
all most every av detects key loggers..
NOD,KAV.. i think even NAV
You and Me forever be ...
PSpwned
Maverick340 is offline
Old 06-03-2007, 07:07 PM   #11 (permalink)
Security Exp
47shailesh's Avatar
Dude tell me one thing truely.. how many times you log on ur PC and are in habbit to check via Task Manager or any process viewer about any malware running most of the times u don't so best habit is to install a good AV like KAV better to have KIS and update ur OS and AV daily...
Old 06-03-2007, 07:09 PM   #12 (permalink)
shantanu's Avatar
^ nice post 47 (47 Hitman) hehe
reps to you if i could...
shantanu is offline
Old 06-03-2007, 07:10 PM   #13 (permalink)
coolboy_n's Avatar
hey,
simply download and install Spybot Search n Destroy and Bazooka Scanner.
they'll detect n remove the keylogger themselves.
keep smiling.
You make your Living with what you Get,
But you make your Life with what you Give !!
coolboy_n is offline
Old 06-03-2007, 07:26 PM   #14 (permalink)
thinkdigitreader's Avatar
U can not see Key logger in add-remove programs.
Regards,
ThinkDigitReader
"Knowledge Multiplies By Dividing"
thinkdigitreader is offline
Old 07-03-2007, 06:16 PM   #15 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
just install Spybot Search n Destroy ........ & click on SCAN .......
ax3 is offline
Old 07-03-2007, 07:06 PM   #16 (permalink)
left this forum longback
praka123's Avatar
Smile Re: how do u know if anyone has installed keylogger
Also a small utility is there most ppl knows it does help knowing unwanted s/w installed or what - Hijack this!
http://www.spywareinfo.com/~merijn/downloads.html
praka123 is offline
Old 07-03-2007, 07:17 PM   #17 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Any AV/AS detects any Keyloggers installed on the system
rakeshishere is offline
Old 07-03-2007, 07:17 PM   #18 (permalink)
Security Exp
47shailesh's Avatar
peoples use HjT only when they are stucked or system responses slow...
Keylogger silently captures the info. wihtout slowing down the sys....
So mostly peoples are screweda at most of the times....
Old 07-03-2007, 07:18 PM   #19 (permalink)
praka123's Avatar
^^ thx for the info-i heard that tool is very useful.infact i remember an article by cooljeba sometime back in a tech_magazine about howto safeguard and use ur passwds whilst ur in Internet
praka123 is offline
Old 07-03-2007, 07:19 PM   #20 (permalink)
Security Exp
47shailesh's Avatar
Yep almost all good ones like KAV, KIS, bitdefender... provided both AV/AS and OS are upto date
