Old 04-03-2007, 03:47 PM   #1 (permalink)
Default Right Click Options
Can anyone tell me how to change/edit or remove the right click option when right clicking on drives.
Its very urgent
Thanks
Krish_88 is offline
Old 04-03-2007, 04:28 PM   #2 (permalink)
Lean mean A@# kickin M/C
apoorv.sharma's Avatar
Default Re: Right Click Options
why ?...gettin an autoplay option on a hard drive ?!
apoorv.sharma is offline
Old 04-03-2007, 05:41 PM   #3 (permalink)
nishant_nms's Avatar
edit/remove autorun.ini in the drive
nishant_nms is offline
Old 04-03-2007, 07:00 PM   #4 (permalink)
uchiha.sasuke's Avatar
exactly wat du wanna edit there???i mean which option.....i know some options which u can edit thru registry....
uchiha.sasuke is offline
Old 04-03-2007, 11:13 PM   #5 (permalink)
Distinguished Member
anandk's Avatar
Customizing Right-Click Menu Options in Windows
http://www.jfitz.com/tips/rclick_custom.html
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 05-03-2007, 12:06 AM   #6 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Open regedit and goto:
HKEY_CLASSES_ROOT\Drive
Under this key, u'll get 2 more keys named Shell and Shellex. These keys contains Drive context menu options.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 05-03-2007, 11:28 AM   #7 (permalink)
Lightbulb Re: Right Click Options
Go to the key where VISTA told you then read this thread for more details
Add a new item to the right click menu of a folder
Or here is the way
a>click on the start menu and click run.
b>Typr in regedit(inbuilt registry editor of windows) and click ok.
c>go to HKEY_CLASSES_ROOT\Drive .
d>Create a new key here with whatever name u want (Name doesnt matters).
e>In its "default" value type in the name which u want to be displayed.
f>Now create a new key in the key which we created in step "d" and name it as "command".
g>In the dfault value type the path of the program.
Now restart and see the effect , wait i think that no restart is needed
Visit now ;)
www.indiandevs.com - for great free designs :)
www.indiandevs.com/technoworld/ for latest technology news and tricks
Siddharth Maheshwari is offline
