Old 28-01-2005, 12:03 AM   #1 (permalink)
Default no: of times xp activation exceeded what to do now
Due to problems with my motherboard my system crashed many times.i used the original xp cd that came with my compaq pc to reinstall.Reinstalling with compaq recovery cd formated entire hard disk and presented with a single partition and no way to change it.So i am using only the xp cd to reinstall.i had to activate it many times till now and succeeded.now i changed my motherboard and when i tried to activate newly installed msg shz up saying no: of times xp activation exceeded please type new product id! what should i do?I tried to contact their service phone no: but not able connect it till now.my xp will be deactivated in 5 more days,IMMEDIATE help needed please..............
rahuljawahar is offline
Old 28-01-2005, 09:04 AM   #2 (permalink)
busyanuj's Avatar
The Windows you're using in an OEM version provided by Compaq, therefore if you change your compaq motherboard to some other one, your license might stand invalidated. But in case you got your motherboard replaced by compaq, you can still continue using your Windows.
to find out more, dial +91 11 2629 2640 and talk to the Microsoft Customer Care Representative.
busyanuj is offline
Old 28-01-2005, 09:37 AM   #3 (permalink)
Go call Compaq they should help yo out .
If they cant go to Microsoft since its an original Win XP they should help you out and i dont think ur liscense stands invalid due to a mobo change.
The cust care will help you out(anyone's)
Have a Nice Day :)
Mohammed Muchhala, © 2006, All Rights Reserved
http://www.muchhalasworld.com
babumuchhala is offline
Old 30-01-2005, 01:12 AM   #4 (permalink)
liquid_nitrogen88's Avatar
hey rahul dude...
just ring up the number given by busyanuj.they will ask for the old activation id,so keep it ready.....then they will provide u with a new activation number.........
branded pc's sucks....especially compaq.......
liquid_nitrogen88 is offline
