Old 04-03-2007, 12:51 AM   #1 (permalink)
::cyborg::'s Avatar
Unhappy ::::bluetooth Problem::::
hi guys
iam having a problem when i want to send files from my phone to computer it has a blutooth file transfer wizard which accepts only one file at a time
i want thatit should accept multiple files .
how can i do it.
i have a bluetooth dongle and iam using windows xp service pack 2
plz help
::cyborg::
:)) - KEEP SMILING
::cyborg:: is offline
Old 04-03-2007, 01:04 AM   #2 (permalink)
Default Re: ::::bluetooth Problem::::
well, its a mobile phone limitation i think, atleast my mobile can't do multiple file transfer simultaneously, because the file transfer screen will show up, and you can't exit it until file is fully transferred or you cancel it!
jack// ani is offline
Old 04-03-2007, 01:19 AM   #3 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
which mobile u r phone using nokia?
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Old 04-03-2007, 06:11 AM   #4 (permalink)
Try to mark all files and then issue send command... I tried it with my photos on my Nokia 6600 and it worked... But I was using trial version of BlueSoleil's software instead of Nokia's PC Suite because the Suite refused to recognise my phone....
Arun
sakumar79 is offline
Old 04-03-2007, 09:08 AM   #5 (permalink)
but bluesoleil provides free software with there Bluetooth dongle....
or get the copy of that CD from a friend whose having a dongle like that....
U r a teen ???
www.allteenforums.com
bugmenot is offline
Old 04-03-2007, 09:25 AM   #6 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
see we cant send multiple files at a time.. what we can do as sakumar79 told is u can mark using some file manager and send and it will send continuously one after another..........
this works with bluesoule as well as XP inbuilt one...
Blogging @ http://classictutorials.com
the.kaushik is offline
Old 04-03-2007, 09:28 AM   #7 (permalink)
The Devil's Advocate
iMav's Avatar
pair ur pc mark the files and send em they shud go ...
http://beingmanan.com
iMav is offline
Old 04-03-2007, 09:50 AM   #8 (permalink)
uchiha.sasuke's Avatar
it depends on cell model.....i have nokia n70,it has dat option....
uchiha.sasuke is offline
Old 04-03-2007, 11:12 AM   #9 (permalink)
sure depends on Mobile
sanju is offline
Old 04-03-2007, 11:41 AM   #10 (permalink)
Gangsta
Josan's Avatar
Location: I come from the land of WARRIORS, land of 5 rivers, where the alcohol will make your liver quiver!!
on my n91,n70 and p990i ,ihav no search prob
and also it must be a prob with ur mobile phone!!!!!!!
Josan is offline
Old 04-03-2007, 11:45 AM   #11 (permalink)
::cyborg::'s Avatar
i have k750i
when i send the file the wizard for accepting the file accept onle one file even if i mark all of tham
and is there anyway to avoid wizard and always keep the port open to receive multiple files
:)) - KEEP SMILING
Old 04-03-2007, 01:31 PM   #12 (permalink)
Google Bot
Pathik's Avatar
all s60 fones can do that
Pathik is offline
Old 04-03-2007, 06:50 PM   #13 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Post Re: ::::bluetooth Problem::::
S80 nokia 9500also send many image to pc
Dell 15z + WD 2TB
iPhone 4 32 GB
Old 04-03-2007, 07:31 PM   #14 (permalink)
Ganeshkumar's Avatar
I am using K700 ... for me it is possible to send only one file at a time... If I Select multiple file... It doesn't have Send Option...
Ganeshkumar is offline
Old 04-03-2007, 07:36 PM   #15 (permalink)
Google Bot
Pathik's Avatar
yea most se fones cant do that..
Pathik is offline
