Old 03-03-2007, 09:52 PM   #1 (permalink)
pavarathy's Avatar
Arrow pls help me on my first dotnet project
Hello frnds.
i am a newbie to .Net technology.
i want to study that.
But while doing c#.net i have some problems that need ur techies advice
I can save images to database as binary.
But the control image in .Net IDE requires a imageurl.
how can i take image url from database.
or how can i display an image which is stored in database?
pls help me.
thanks in advance
pavarathy is offline
Old 03-03-2007, 10:15 PM   #2 (permalink)
CG Artist
gaurav_indian's Avatar
Default Re: pls help me on my first dotnet project
Dont store images in the database.Store them in one folder.Make a field in database for ex:- "webimages" then in database coding set the default path to C:/imagefoldername/webimages
gaurav_indian is offline
Old 03-03-2007, 10:25 PM   #3 (permalink)
pavarathy's Avatar
^^ thank u frnd for reply.
but is this possible to link image stored in database to image control?
Old 03-03-2007, 10:27 PM   #4 (permalink)
CG Artist
I haven't tried that.
Old 05-03-2007, 04:37 PM   #5 (permalink)
piyush gupta's Avatar
Why storing images in Database
store them on folder and makea table in databse about images name path and extension
not u can pass this path in Image Control
piyush gupta is offline
Old 06-03-2007, 01:06 AM   #6 (permalink)
MMO Addict
amitava82's Avatar
yes its possible to link. you can also store image data to database. i did it with VB.net (visual studio 2005). dont know the codes for C. go through MSDN. you will get the syntax.
if you use visual studio 2005 then you don't need to write any code. create sql table. then drag n drop the table to a form. visual studio will automatically create all the necessary controls including image control for image. its very easy.
Steam Profile || Personal Page
Warp drive active. Approaching stargate.
amitava82 is offline
