Old 03-03-2007, 01:23 PM   #1 (permalink)
hailgautam's Avatar
Default Personal Wiki - user reviews
Personal wikis allow people to richly link information on their desktop or mobile computing devices the same way a community wiki links information across the internet. Thus people who like the wiki philosophy of organizing information may find personal wikis useful.
So, how many of you have used and what application you have used. Can you suggest me a good one to use only in the desktop environment/ local network environment.
In case you want to know more..
Comparison of wiki software
List of wiki software
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 03-03-2007, 01:32 PM   #2 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Default Re: Personal Wiki - user reviews
BTW... Didja try out TiddlyWiki? Real nice personal web notebook wiki...
koolbluez is offline
Old 03-03-2007, 02:19 PM   #3 (permalink)
18 Till I Die............
I am currently using Dokuwiki on my PC. It's got really nice features for a small home user. It doesn't make use of any DBMS so it's way lighter on resources.
Check out http://wikimatrix.org they've given a lot of info on wiki's. Choice wizard on their site is a nice tool http://www.wikimatrix.org/wizard.php that's what helped me in finalising dokuwiki.
I did try Media Wiki before but it seemed a bit unsuitable or should I say oversuitable for me needs.
Dokuwiki on the other hand is small and powerful. Not too many complications out of the box. But, you can edit the files and get a lot of things done with it.
http://www.bash.org/?258908
mehulved is offline
Old 03-03-2007, 02:43 PM   #4 (permalink)
hailgautam's Avatar
Ya 40 mins and not able to change the name of the title of the page yet, no man these things has to be easy to edit and change,
However it is quite small and comfortably a single file where ever you save, great if you want to carry a wiki on a pen drive..
Where you going?
With Luck forward.
Old 03-03-2007, 02:43 PM   #5 (permalink)
Maverick340's Avatar
huh ? whats the use ? and how is it different from normal wiki softwares like mediawiki ?
You and Me forever be ...
PSpwned
Maverick340 is offline
Old 03-03-2007, 02:50 PM   #6 (permalink)
hailgautam's Avatar
I have been able to add new posts or what ever you call them, but I could not change the name....if you want to know more just download and try....it is very easy that way.
Where you going?
With Luck forward.
Old 03-03-2007, 03:32 PM   #7 (permalink)
Maybe there's a file in where you can make the changes. In dokuwiki I did it that way only.
Tiddlywiki on tiddlyspot feels way too slow and complex.
mehulved is offline
Old 03-03-2007, 03:48 PM   #8 (permalink)
hailgautam's Avatar
Is PHP or something is needed to install??
Where you going?
With Luck forward.
Old 03-03-2007, 03:59 PM   #9 (permalink)
If you mean tiddlywiki then no. It works on javascript. Not even a web server needed.
For dokuwiki you need a web server and php installed.
__________
I guess tiddlywiki won't work for quite a lot of people, they've javascript disabled.
mehulved is offline
Old 03-03-2007, 04:11 PM   #10 (permalink)
hailgautam's Avatar
__________
No, Tidywiki works fine, infact i also tried the MoinMoin it is also working fine..
Problem with your Docuwiki, MediaWiki and Dekiwiki, I think they want Apache, PHP MySQL etal to be running.....
I would not be able to do that
Where you going?
With Luck forward.
Old 03-03-2007, 05:46 PM   #11 (permalink)
No mysql is needed for Dokuwiki. It's optional if you want to enable it. Why can't you run apache and php? You get servers like xampp which are like ready made and so easy for noobs.
I found tiddlywiki to be pathetically slow.
mehulved is offline
Old 03-03-2007, 08:55 PM   #12 (permalink)
hailgautam's Avatar
^^ya it is slow on the net i browsed some example sites and found them to load very slow. i think you are posting to web or on to the web. i am trying to use tidywiki on my standalone system so no issues here.
i installed apache but was not able to install php, as i downloaded the zip version. i will download the msi version and will try.
is xaamp alternative to apache or php?
Where you going?
With Luck forward.
Old 04-03-2007, 05:44 AM   #13 (permalink)
xampp is apache + mysql + php + perl
http://www.apachefriends.org/en/xampp.html
mehulved is offline
Old 04-03-2007, 03:34 PM   #14 (permalink)
hailgautam's Avatar
wow that's great thanx very much..
Where you going?
With Luck forward.
