Old 01-03-2007, 11:00 PM   #1 (permalink)
9437077259
go4saket's Avatar
Question How to convert DV-AVI to XVID???
Hi guys!
How can we convert DV-DVI to XVID format. I use Auto Gordian Knot to convert my DVD's and other MPEG to XVID but unfortunately it doesnt support DV-AVI. Please help.
Chao.
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
Old 06-03-2007, 03:35 PM   #2 (permalink)
aj27july's Avatar
Default Re: How to convert DV-AVI to XVID???
I use IMTOO DVD RIPPER Platinum 4.
Better than the best. The formats supported are numerous.
It is the beshhhhhhhhht.
The moment you start looking for the truth,
you are no longer a part of the mob,
you become an individual.
----OSHO
aj27july is offline
Old 06-03-2007, 07:28 PM   #3 (permalink)
Google Bot
Pathik's Avatar
super/xilisoft
Pathik is offline
Old 07-03-2007, 03:44 PM   #4 (permalink)
I saw your same post in one more forum by googling
see these links of the same forum
http://forum.doom9.org/showthread.php?t=60392
http://forum.doom9.org/showthread.php?t=32197
Visit now ;)
www.indiandevs.com - for great free designs :)
www.indiandevs.com/technoworld/ for latest technology news and tricks
Siddharth Maheshwari is offline
Old 07-03-2007, 04:41 PM   #5 (permalink)
9437077259
go4saket's Avatar
Thanks siddarth, but the link you provided are to convert DV to DVD and anither for DV to DIVX and not XVID.
Win 7 Ultimate
go4saket is offline
Old 07-03-2007, 04:49 PM   #6 (permalink)
gooby pls
Third Eye's Avatar
Try Xilisoft Video Converter
Third Eye is offline
Old 07-03-2007, 05:02 PM   #7 (permalink)
Try this if it isnt useful then tell but i think it should be useful
http://forum.videohelp.com/viewtopic.php?t=244151
http://www.riverpast.com/en/support/...rt/xvid/dv.php
Plz do reply
Visit now ;)
Last edited by Siddharth Maheshwari; 07-03-2007 at 05:12 PM. Reason: Automerged Doublepost
Old 09-03-2007, 07:17 AM   #8 (permalink)
Traceur
zegulas's Avatar
Plz do reply
OK, now I myself have a camcorder and have converted DV-AVI to Xvid.
The results are great, very minimal loss in video quality. Now dude, if you have problems getting all the codecs mentioned in the above link then try installing K-Lite mega codec pack (latest). You will get everything in it, be it LAME MP3, Xvid, DivX etc.
Then do as give in there, use Virtual Dub:
1.Open the video file in virtual dub
2.Deinterlace
3.Resize
4.Select Video compression type
5.Select audio compression type
6.Save the file as AVI and you are done.
Now if you don't know how to do all this then please let me know, I will tell you everything in detail then.
zegulas is offline
