Old 10-08-2004, 04:47 PM   #1 (permalink)
I WANT MORE FPS!!
adithyagenius's Avatar
Default MP3 cutter. Suggestion anyone?
I have an album in one mp3 file. I want to cut it into songs and separate them without losing quality. Which tools should i use?
adithyagenius is offline
Old 10-08-2004, 06:03 PM   #2 (permalink)
try Cool Edit Pro. That gives u precision cutting capabilities. Also google it dude..there are plenty of tools !!
MP3 Cutter
http://home.hccnet.nl/p.luijer/
Power MP3 Cutter
http://www.cooolsoft.com/mp3cut.htm
and there are zillions more.....
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 10-08-2004, 11:26 PM   #3 (permalink)
Default Nero Wave Editor
Use Nero Wave Editor. That is one of the best tools I have ever seen. Also you can add effects.
To mix music, use Nero Sound Trax....
sUlPhUr|nE` is offline
Old 11-08-2004, 12:34 AM   #4 (permalink)
hafees's Avatar
dont forget the Soundforge
hafees is offline
Old 11-08-2004, 12:15 PM   #5 (permalink)
Default Yeah! forgot
Sony SoundForge is also very good. You can also use Sony Acid Pro to mix tracks....Its really wonderful
Old 18-08-2004, 02:37 AM   #6 (permalink)
Cool Edit Pro, is the best.
Adobe Audition has a trial version......
The list simply keeps going on buddy!
prathapml is offline
Old 19-08-2004, 12:39 PM   #7 (permalink)
goldwave, soundforge and nero's wave-editor r the best bet.
prankzter is offline
Old 19-08-2004, 05:07 PM   #8 (permalink)
Soundforge , too many controls , so little time
Walk on the Wild Side. The other side SUX!!!
krazydude is offline
Old 20-08-2004, 01:31 AM   #9 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Audacity ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 20-08-2004, 03:35 AM   #10 (permalink)
Has anyone of you seen "VirtualDub" ?
Can cut/merge A/V streams, can open save to whatever codecs you have installed - and is freeware. Google to find it.
Old 20-08-2004, 11:27 AM   #11 (permalink)
VirtualDUB is predominantly used for video files. You can do all of the above with the audio extracted with video files. However u cant precisely place and position with audio files which other tools such as Cool Edit Pro or Soundforge will give you...
AMD 64 3500+ Venice
icecoolz is offline
Old 20-08-2004, 12:57 PM   #12 (permalink)
goldwave,cool edit pro, Fruty loop, Sound forge,mp3 splliter(etc etc etc)
google it yaar
Music is like Sex, The more you get, the more you want.
demoninside is offline
Old 21-08-2004, 12:47 PM   #13 (permalink)
Use Goldwave 5.08
Don't forget to download mp3 encoder lame32 if you want to save the processed file in mp3 format.
Goldwave is shareware and lame32 is freeware. You download both of them from www.goldwave.com. Goldwave (1.6 MB) and lamewin32 (622 KB)
jnpandya is offline
Old 22-08-2004, 12:49 AM   #14 (permalink)
Ashis's Avatar
Dont think Just do it Cool with Cool Edit Pro ! 8)
Ashis is offline
