Old 01-03-2007, 06:30 PM   #1 (permalink)
Red face Can't Open Hard Disk Drive
i m using winxp and i install norton antivirus 2007 since i install NAV07 i can't access my drives my drivers show me message "open with". my drivers always show "auto play" i scan my pc with antivirus but i didn't find any kind of virus. CAN ANY ONE GIVE ME SOLUTION
agasti is offline
Old 02-03-2007, 12:33 AM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Can't Open Hard Disk Drive
Search for autorun.ini file in root of each drive, e.g., in c:\ and delete such files.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 02-03-2007, 09:37 AM   #3 (permalink)
More or less similar to what Vishal said.
This is from another forum:-If your hard drive right-click menu has an "autoplay" option, it maybe some Trojan horse on your hard drive.
First, reboot your system and get into the safe mode.
Second, change setting to show all files on your hard drive
Then, if there is a file which name is "autorun.inf"under your hard drive's root directory, delete it.
You must delete the Trojan horse under the hard drive's root directory and delete the start-up option of it
After that, reboot your computer.
All done!
Now look at your hard drive right-click menu, the "autoplay" option is disappeared. "
vkr15 is offline
