Old 27-01-2005, 03:35 PM   #1 (permalink)
vignesh's Avatar
Default live cd
i have tried a lot of live cds but i get a sync out of range error while booting into ythe gui .Can anyone tell what to do and how to make it ok.
vignesh is offline
Old 27-01-2005, 03:47 PM   #2 (permalink)
Lower the screen resolution & then try.Or you can changing the resolution when in command line mode when you boot off the cd.
Which distro are you trying?
www.Oobertech.net
digen is offline
Old 27-01-2005, 04:06 PM   #3 (permalink)
vignesh's Avatar
i tried slax and knoppix.how do i reduce the resolution.can you tell me the steps.
vignesh is offline
Old 27-01-2005, 04:13 PM   #4 (permalink)
For knoppix at the boot prompt,
knoppix screen=1280x1024
where 1280x1024 is the resolution that you want to set.
I dunno about slax dude.
www.Oobertech.net
digen is offline
Old 27-01-2005, 05:00 PM   #5 (permalink)
vignesh's Avatar
it was a problem with the refresh rate.
vignesh is offline
