Today wen i switched on my computer, i noticed MY DOCUMENTS folder is hidden and i cant restore it coz the HIDDEN option is greyed out. i searched the computer 4 spyware and Viruses, but none of it was found. Urgent help needed. Plz. I m using WINDOWS XP and it is visible on d dsktop but not visible in MY COMPUTER. it is shown slightly transparent.
Shwetanshu Srivastava
Please be more specific. What OS do you use? Where are the My Documents not appearing - on the Desktop? If that's the case, then try accessing the Display properties in XP, and on the Desktop tab, select Customize Desktop. Make sure My Documents is selected.
