Old 27-01-2005, 03:28 AM   #1 (permalink)
Default Virtual memory minimum too low.What to do
getting this error while using many applications
i have 128 mb ram
win xp
is there way to increase Virtual memory
thanks
AMIT AGARWAL
AMITAGARWAL02 is offline
Old 27-01-2005, 09:23 AM   #2 (permalink)
swatkat's Avatar
1]Click Start, right-click My Computer, and then click Properties.
2]In the System Properties dialog box, click the Advanced tab.
3]In the Performance pane, click Settings.
4]In the Performance Options dialog box, click the Advanced tab.
5]In the Virtual memory pane, click Change.
6]Change the Initial size value and the Maximum size value to a higher value, click Set, and then click OK.
7]Click OK to close the Performance Options dialog box, and then click OK to close the System Properties dialog box.
Set virtual memory Minimum size twice the RAM.
http://support.microsoft.com/default...b;en-us;826513[/quote]
http://swatrant.blogspot.com/
swatkat is offline
Old 27-01-2005, 03:51 PM   #3 (permalink)
Do as swatkat says
Also disable all those eye canies that XP comes with, reduces a lot of requirements.
1]Rght-click My Computer, and then click Properties.
4]In the Performance Options dialog box, u get VISUAL EFFECTS
5]Check the adjust for best performance.
6]Click OK.
Reduce Your start up list
Run --> msconfig --> startup --> Disable all.
Restart
You will see a performance boost. and wont get a Virtual MEM too low msg
Have a Nice Day :)
Mohammed Muchhala, © 2006, All Rights Reserved
http://www.muchhalasworld.com
babumuchhala is offline
Old 28-01-2005, 01:04 AM   #4 (permalink)
Thanks babumuchhala
I have disabled all that
and tick at adjust for best preformance long time back when win xp was installed.
Thanks.
Thanks swatkat
Actually my ram is 128 mb - 16 mb = 112
Initial size value is 168
and the Maximum size is 236
Now i have increased it.
Hard disk is more than 7 Gb Free
so upto which maximum setting can i put Initial size value and the Maximum size
please tell me that
and how to know Virtual memory usage
is there any meter for it
I have meter for mem load,physical load and swap file
thanks
AMIT AGARWAL
Old 28-01-2005, 09:44 AM   #5 (permalink)
press ctrl+alt+del to get the task mannager
Go to the prrocessor tab click on view menu and select column. there tick mark virtual mem. and mem usage
This will show u memory and virtual memmory used by each app.
Go to the performance chart there u see 2 graps first is cpu usage graph second is Page File(Virtual Mem Graph)
Then there is a box showing hysical memory stats. ie mem installed, current usage and free ram available
There is a Free RAM XP Pro freeware.Its an excellent utility to free up mem when u require
Have a Nice Day :)
Old 28-01-2005, 02:04 PM   #6 (permalink)
swatkat's Avatar
Optimally , the relation is, Initial Size+RAM>=500MB.
So in ur case as RAM is 128(112) MB, Set the initial size as some 400MB and Maximum Size can be anything between 700MB to 800MB.
Take a look at this page for more info.:-
http://aumha.org/win5/a/xpvm.php#HowSet
please tell me that
thanks
Swap File is same as the Page File, which is the Virtual Memory.
So Swap File usage is Virtual Memory usage.
There's one tool to montior Page File in XP, called XP PageFile Monitor.
http://www.dougknox.com/xp/utils/xp_pagefilemon.htm
swatkat is offline
