Old 28-02-2007, 05:02 PM   #1 (permalink)
MVP Awardee 07
uzair's Avatar
Angry Where is the shutdown dialog?
my sys runs win xp mce
i dont get a dialog similar to this in the attachment...
I simply get a drop down list box with options shutdown logoff and all in a dialog ...
I want a one similar to the attachment...
help me out
Probability of me getting a ps3=0
Probability of me getting crazy about ps3=1
uzair is offline
Old 28-02-2007, 05:51 PM   #2 (permalink)
Back From Deathstar
Darthvader's Avatar
Default Re: Where is the shutdown dialog?
Do u get this then it is not a problem at all as this is for MCE
.......Trust is a Weakness......
Guess what I am back after a long long long time :lol:
Darthvader is offline
Old 28-02-2007, 05:57 PM   #3 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
Arrow Re: Where is the shutdown dialog?
Hey buddy......
Go to
1. Control Panel
2. Open User Acounts
3. In Pick A Task-
Choose the Option Change The Users LogOn Or Off
4. Clcik On Use The Welcome Screen..........
5. Apply Options.........
But Buddy if it tells u that "Client Services for Netware has disabled the Welcome screen and Fast User Switching. To restore these features , you must uninstall Client Services for Netware.""
Then
To disable this effect U can..............
1. Open Control pannel
2. Click To Network Connection
3. A window wil appear
4. Right Click On Icon For Example-
Dail Up Connection
Virtual Private NetWork Connection
5. A menu Will Appear
6. Click On Propertise
7. A dialog Box will Appear...
8. There will be many tabs Ex Genral, Options, Security, Networking.
9. Click On Networking Tab
10. A dialog box will be dispalyed which shows:
THE CONNECTION USES THE FOLLOWING ITEMS
11. Now, As u scoll down it will dsplay all the uses of connection.
12. You willl also see Client services For NetWare which will be checked
13. Uncheck that Box...... and Click The Uninstall Tab.........
14. cLCIK OK
15. restart UR Pc.....
16. DO THE WORK......
And if u want to customize your windows Shutdown/log off dialog box:
The Refer To This Link
TUTORIAL: Make Your Windows XP look-a-like Windows Vista
||uLtiMaTE WinNER||
Ron is offline
Old 14-03-2007, 12:58 PM   #4 (permalink)
MVP Awardee 07
uzair's Avatar
Lightbulb Re: Where is the shutdown dialog?
when i try to enable fast user swithching and the xp login screen...
A dialog appears saying Clint services for netware has disabled fast user swithching and the xp login screen...to restore uninstall client services for netware.... how do i uninstall it...
In add or remove progs there is no such entry called client services for netware...???
uzair is offline
Old 14-03-2007, 01:02 PM   #5 (permalink)
Tech Geek's Avatar
http://www.uwplatt.edu/oit/howto/removenwc-win.html
Tech Geek is offline
Old 15-03-2007, 11:52 AM   #6 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
For Example-
Dail Up Connection
14. cLCIK OK
Buddy..........Read The post carefully!!!!!!!!
||uLtiMaTE WinNER||
Ron is offline
Old 16-03-2007, 04:22 PM   #7 (permalink)
MVP Awardee 07
uzair's Avatar
Red face Re: Where is the shutdown dialog?
oh sorry
i missed you that...
uzair is offline
