Old 28-02-2007, 10:39 AM   #1 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Default iColorFolder v1.4.2
Organise your files more easily
With iColorFolder, give some color to WindowsXP folders.
With just a right-click, colorize your folders, and discover
a new intuitive way to classify your files. A quick view is
now enough to identify the folder you are looking for !
Classify your folders by Family
You can now classify your folders by Family. Red is an Important
folder, Orange is Urgent, Green is Familial... Choose the attributions
that you like, so you'll never delete an important folder by error.
A fast and light tool
iColorFolder is a very light soft, that doesn't stay in memory. It uses a native
functionnality of WindowsXP to be more efficient. Discover it's simplicity : with a
single right-click on a folder you colorize it ; the necessary and only the necessary.
iColorFolder is proudly an Open-Source program.
Fully skinnable
iColorFolder is bundled with three apparences : the default apparence of WindowsXP
folders, a Mac OS X skin and a Snow.E2 skin. If your system is already
customized with shellpacks like WinOSX,
you'll keep the same folder apparence. You can find other skins on the Web or even
easily create one yourself.
Some images tells more than a thousand word
You'll find in the Screenshots Section some
images describing iColorFolder and presenting it's functionalities. Try it ! If you
didn't like it, you can uninstall it fully and quickly.
DOWNLOAD
Edit:Trust me Guys,U will really Like this softie
rakeshishere is offline
Old 28-02-2007, 02:56 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
ya its a nice one. had talked about it here color your folders with iColorFolder
more such :
WindowPaper XP
Shedko Badges.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 28-02-2007, 03:55 PM   #3 (permalink)
trigger's Avatar
Default Re: iColorFolder v1.4.2
yeah,.... nice sw.. already using it...
Are you watching closely?
trigger is offline
Old 28-02-2007, 05:07 PM   #4 (permalink)
aryayush's Avatar
Yeah, it is a good software. Even better than Mac OS X's default function.
If they could only improve the look of it by adding subtle reflections and anti-alaising, it would look much cooler.
aryayush is offline
