Re: Whats the ....
1.Gmail is well-known for the use of Ajax programming in its design
2. Advanced search strings can be constructed, using either the Advanced Search interface, or search operators in the search box. Search options include search for phrases, message located and message date.
3 By default, Gmail uses an unencrypted connection to retrieve user data, encrypting only the connection used for the login page
