25-02-2007, 04:06 PM
Is it possible?
I have four partitions on my hard disk. I have WinXP SP2 on D and Win98 on C.can I format my C drive and reinstall Win98 on it, without affecting anything on the D drive including winxp?
How will i start my win xp? Any suggestion?Thanks in advance.
25-02-2007, 04:34 PM
||uLtiMaTE WinNER||
Re: Is it possible?
There will be no effect in d: including Win xp untill and untill u dont create part ion or format the drive also........Formating Ur c: will mk no harm to other drives...............
After reinstalling win98 in ur c:.........u can start win xp.......as usually u start......You will find no changes.....
||uLtiMaTE WinNER||
25-02-2007, 04:42 PM
Re: Is it possible?
boot menu will be avaiable after reinstallin win98????
25-02-2007, 04:44 PM
TechTin.com
Re: Is it possible?
hey U can do that..............
But I scared u may face some problem in boot screen.according to microsoft,U should install the never version after the old version.
And XP is newer than win 98...........so U should install XP after win 98.
25-02-2007, 04:52 PM
Re: Is it possible?
25-02-2007, 04:55 PM
TechTin.com
Re: Is it possible?
how u will do that??
25-02-2007, 05:16 PM
Re: Is it possible?
Why do you want win 98 when you have xp?.
25-02-2007, 05:31 PM
TechTin.com
Re: Is it possible?
^^^..I also want to ask the same Q............I have seen many people having both win 98 n XP.Some of them say that..they keep win 98 to play games.According to them,win 98 is better for games than XP.
25-02-2007, 05:33 PM
eWebGuru
Re: Is it possible?
if you will install win98, boot menu will not appear I think, you computer will directly stat win98.
Windows and linux hosting at http://www.ewebguru.com
Get $50 per blog post PM me for details.
25-02-2007, 05:39 PM
TechTin.com
Re: Is it possible?
I also think the same...I have also mentioned this before in this thread only.
25-02-2007, 06:05 PM
Google Bot
Re: Is it possible?
u hav to install xp after u install 98 if u want to keep both...
n all games run well in xp too.... 98 sux..
25-02-2007, 06:21 PM
Re: Is it possible?
Just copy current boot.ini into some other partition nd after 98 reinstall paste it back to C root. Now u can boot into XP.
G3: XPS M1530 |
FZ 16.
25-02-2007, 07:31 PM
TechTin.com
Re: Is it possible?
can U please explain in more detail.
thanks in advance...
25-02-2007, 11:45 PM
Re: Is it possible?
old games like max payne,recoil,igi do not run on xp....
U need W'98 for them
AMD X2 260, GA M68MT-S2P, Gskill RipjawsX 4GB, 500Gb Seagate, Cooler Master eXtreme Power Plus 600W, Altec Lancing atp3, Samsung B2230 TFT, Numeric Digital 600 EX-C UPS.
25-02-2007, 11:49 PM
TechTin.com
Re: Is it possible?
26-02-2007, 12:04 AM
Re: Is it possible?
yeah you have to install winxp, after you installed win98.
26-02-2007, 10:32 AM
Re: Is it possible?
i have to keep win98 because my cd writer does not work in xp....and during the computer show black screen,says dumping memory and restarts.
26-02-2007, 10:41 AM
Re: Is it possible?
First enable display of hidden files nd folders as well as system files. U can do this in folder options. Then go to C:\ and locate file boot.ini nd just copy paste it into some other partition nd after formatting nd reinstalling of 98, just repaste the boot.ini into C:\ nd u will again get the choice of booting into XP. Now if u want then go to folder options nd hide the system files so that u accidently does not delete any system files.
G3: XPS M1530 |
FZ 16.
26-02-2007, 10:45 AM
#19 (permalink)
TechTin.com
Re: Is it possible?
^^^I think he need to edit the boot.ini file of XP(which he has saved ealier).
By editing i mean he need to add the win98 line....than only win98 will be detected.
Am I correct??plz conform it?
26-02-2007, 10:48 AM
#20 (permalink)
Re: Is it possible?
Just run them in compatiability mode. You will be fine. I ran pretty old dos games in XP and it ran fine.
Also i suggest you to remove 98 from your system. Nowdays there is no softwares,games and others that do not run in windows 98. 98 is very old and microsoft stopped supporting the os. I suggest you to start use XP
26-02-2007, 12:35 PM
#21 (permalink)
Re: Is it possible?
Just take a backup of ur boot.ini file on Cd or USB drive or something like that
now reinstall Win98
just replace ur C:\boot.ini with older one
done
Search this Thread |
