Old 23-02-2007, 01:50 PM   #1 (permalink)
Default hidden files not shown.
i clicked on the option of "show hidden files and folders"
on folder options>view settings.
but when i press ok to save the setting then nothing happens.
hidden files r not shown.
and when i checked again then it seems that
the changes made had not been saved..
so plz help me, how i can be able to see the hidden files again.
thanks.
thadhanihemant is offline
Old 23-02-2007, 02:05 PM   #2 (permalink)
Kiran.dks's Avatar
Default Re: hidden files not shown.
Opening Registry editor:
Propagate to Key:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
In the right pane, change the value of "Hidden" to 1.
This might happen due to virus infection. Post the HijackThis report for analysis.
Kiran Kumar R
Kiran.dks is offline
Old 23-02-2007, 03:43 PM   #3 (permalink)
Hmm.. The files u r trying to see are the system files, so in the same window where u checked this option, scroll down some more and uncheck "Hide protected OS files with selecting option "Show HIdden Files n folders". click ok n Whoaa...
Brother of Michael Schumacher is Here...
Pradeep Kashyap is offline
Old 23-02-2007, 05:26 PM   #4 (permalink)
cooldip10's Avatar
May be there are no hidden files after all..
Everything is Possible
cooldip10 is offline
- by Piyush
